American Racing Ventura 10x15
Noppes
Mönchengladbach , Germany
I can get 4 Rims from American Racing in 10x15 . What do you think about this Rims with 33 Tire on the Tj
And from where i can get some Documents ?
Personally I like the look of 33x12.50 on 15x8 rims better. Are you looking for backspacing data and things like that for the 15x10 rims?
Technical details for MPN# AR1365165
Part Number: AR1365165
Name: American Racing Ventura AR636 636 AR136 136 Polished Custom Rims Wheels
Model: AR636 AR136
Finish: Polished
Diamter: 15"
Width: 10.00"
Bolt Pattern: 5x114.3
Offset: -44mm
Hub Bore: 83.10mm
Back Spacing: 3.77"
Load Capacity: 1600 LBS
Center Cap#: 1327000S
TPMS Compatible: No
Weight: 24.18 LBS
Price: Discontinued
Thats what i looking for !
Is it posible to get an offical data Sheed ?
I checked American racing's website, they still make a version of this wheel but its in a 16x8 size. I can't find any data other than what I posted above for the 15x10. The data that I provided is as "official" as it gets. Maybe someone has an old catalog from American racing that can help.
Thank you , i think i will buy the Rims .
When you buy Rims in the USA did you get some official Papers with it ?
I've bought one set of rims used (no paperwork) and one set of rims new. The rims I bought new happened 20 years ago and I don't remember if I got all the paperwork/specs wit them when I ordered them.
15x8 is recommended because when you air down there is more force on the sidewall and less chance of losing a bead than with a 15x10 wheel running the same tire. I had a AR 15x7 wheels at one point and they balanced just fine. You just want to make sure all the rims are true before you buy them otherwise you will not be happy if you can't get thing balanced.
Reactions: JMT
