AndyG's Genright painted fender install
AndyG
Because some other guys are perverts
Lifetime Supporting Member
Alabama
I got these last year because I was infatuated with @Plumber1 s awesome 06, had them painted and finally got around to it-
This thread concentrates on the front because the rear are a pretty simple bolt on affair.
I think a lot of my intrepidation was I was intimidated by the job and the instructions didn’t show as much as I wanted in terms of where to cut-
I started with getting a good template from them and getting it printed onto card stock.
Then made the marks and cut with an angle grinder -
Then sealed all bare metal with POR 15
Then we dry fit- At this point you start to see what you’ve got to get out of the way and that’s going to be the battery box and fender swells that accommodate the battery box- I’ll add a little detail to that later, but you can avoid having to get too radical with a some creative massaging and trimming.
Regardless, once you
start you have got to do what you got do-or you’re really going to be fighting it-you can see the “rolls” in the tub form at the battery box that prevent the fender from pulling up-rather than pull the battery and battery tray on this side we just hammered these flat and relieved the fender a little bit around the top roll with a plasma cutter - dont get hung up using the 2 fender well bolt locations - be prepared to relocate those 2 if you want less drama- same end result.
The picture below is what you don’t want and this was during the dry fit stage-the hi lift and persistence fixed this- these things do not just “bolt on”. They have to be fitted.
At this point I was happy once I started to see what I was going to end up with and a strategically put urethane at all the connections, after POR 15 of course-
Now I’m ready for the final bolt up and everything went good but I’m still fighting the passenger side a little bit so I did some persuading- The manufacture even recommends ratchet straps and not pre-painting your components so that you can get pretty rough with things-
I inserted the top bolts once I was happy with its position-
This all worked out good and I wanted something better than the rivets at the very top and I always hang onto the milk jug bolts- These will ultimately get painted black or white-
I used a 7/8 diameter washer and nylock nuts underneath-
I will grind off any threads so I don’t catch a tire this pm-
Last will be rerouting the light wires- will post that soon- this is optional, but we have lots of foliage in the south and tucking them in is good.
The light wiring is straightforward but you can’t have a completely stock wiring set up without a lot of electrical know how- You simply delete the marker light lead and the run the running light lead from the original turn signal on the front, and power the marker light and the blinker lead powers the 3/4” led blinker and they share the ground. You do need the LM 470 relay.
I’m really happy about the total package and I’ll try to post some more details later-
For some reason it will not let me delete that last duplicate picture- But if anything that is the most critical area as far as cutting you can’t leave too much but you can’t go too far inbound- As you’re doing that helps above the tire to just cut the fender in half- You can deal with the front and the back disconnection separately
Looks good, Ange. Nice work.
Reactions: AndyG
Looks great!
Now maybe you can change your profile pic to your own rig, and not that other guy's... :LOL:
Awww come on man. Creativity is just well disguised plagiarism.
You know @Jerry Bransford is the man. I just needed to borrow some cred. He only charges me $25 a month to use that pic.
Not my cup of tea, but you sure did a hell of a nice job on them.
Thanks. In one sense I have mixed feelings - Even when I was doing them I thought “this is crazy.”
I don’t think all Jeeps should look this way it’s just something that I wanted to do once in my life-
If I had never seen Plumbers’ I would have never considered it. I’ll post some pictures in a little bit that show where I took it little further.
This is my favorite detail-
Instead of forever pulling bugs out between the fenders and the grill I filled it with urethane-
It will get a black version on the backside to keep the tire from filling it up with mud and debris and eventually creating rushed and it will be left open on the bottom so it could drain if moisture ever got in it
Now its just nitpicky details-jeep has a 2” Ome lift, 1.25 or so body lft, Clayton arms. Zj steering, mild tuck, exogate, ucf rear bumper, bedtread in rear , bartacts, new radiator, jks style links in front, adj track bars, ome shocks, winch with remote, remote lights on the roof rack-
Ready to have fun.
Pic below is the day I got it-
I’ve tried to sweat every detail- I bet you could fill a gallon jug with the dirt I’ve got out of this thing-
