Hello There,
I tried doing the jumper harness mod for the front side marker lights/turn signals and was partially successful but have a couple issues I can't figure out.
Current Jeep status:
- Rear taillights all converted to LED's
- Installed the LM470 flasher relay
I followed the schematic I attached and included an image of my franken-harness I built for testing.
Issues are:
- Lights off >> side and front blink together
- Lights on >> side and front blink together
- I have a 1W 1000ohm resister in the circuit and the side marker light doesn't dim at all >> should I just continue adding resisters in series until it dims?
I also tried rotating the plug 180 deg with plug and light and only created more problems.
Thank you
Issues are:
Thank you
