Any advice on installing Currie 4” at home?
ARawls88
Ohio
Any tips, secrets or tricks of the trade for doing this at home? All help is much appreciated!
Brianj5600
Middle Tennessee
Invite a friend or two and buy pizza. Spring come out and go in with out a spring compressor if you remove track bar, shocks and steering if it is stock. A prybar and heel prybar will be nice. Torx bits, 18mm and 21mm socket and/or wrench.
WHBNM
New Mexico
It is pretty straight forward. A few things that I was glad that I had -
A nice floor jack (two for cycling suspension). I used one nice one and one so-so. Nice tall 6 ton jack stands and nice scraps of 2×12 and assorted blocks help. A set of drift(alignment) punches. Two 3/8" ×6"socket extensions. A 5/16" hex/Allen x 3/8" drive socket. Taps and a strong t-handle for new bump stop bolts if you're installing those. PB Blaster for a day before especially upper rear shock mounts, front jounce cups. Antiseize for new hardware.
Reactions: ARawls88
someguysjeep
Lifetime Supporting Member
ohio
where ya at in Ohio?
a pinch bar is worth it's weight in gold sometimes.
scottgraham
Just another bad habit
land of waterfalls
PB-Blaster is barely better than WD-40.
...But it can melt a styrofoam cup!
Back when they had TV ads... (TV, means 📺 for you youngsters). That used to crack me up!
Next time I need to melt a cup, I know where I'm gonna turn.
I've got a full can in the shed that should prb be on antique roadshow.
Reactions: ARawls88
Feralkid
Adult Baby Diaper Enthusiast
Se pa
Kroil, Liquid Wrench, and Break-Free (in that order) all work significantly better. PB-Blaster is barely better than WD-40. 😊
WD40 > PB blaster
the only thing pb blaster is good at is being a carcinogen
Chris
Administrator
Staff Member
Florence, AZ
I installed my Currie 4" lift in the garage, by myself. It wasn't terribly bad, I just recommend an impact wrench, jack stands, a good hydraulic jack, metal drill bits, and a tap and dye kit so that you can drill the lower spring perches and tap them for the bolts that hold in the bump stops.
Pace yourself and don't try to do it in a day. It took me a weekend, but I paced myself and took lots of breaks.
A
ARawls88
Ohio
Got most of the front end disassembled last night, wasn’t as bad as I thought. I’m making a list as y’all keep responding so much appreciated and keep it coming. Impact has definitely come in handy too!
Queticon
Minnesota
1. If you get tired, stop working.
2. After everything's installed, take a nap
3. Come back later and make sure everything is tight/torqued to spec
When I installed my lift, I was lucky to find a friend with a heated garage to use for a day. Just a day. I had done a lift install before, but this was also going to be new track bar and trailing arms. Started around 10 a.m. Rolled out of there around 3 a.m. Exhausted. Over the next month, I was chasing down rattles and squeaks due to shit not being tightened properly.
If you have time, take it.
and for anyone else doing this, gather up your loose change and pick up one of these:
I've had mine for 10 years and the thing is amazing.
A
ARawls88
Ohio
I’ve got plenty of time. If it takes me a week so be it. This is all new arms, track bar and the works. So I want it done right the first time. But I’m sure I’ll be chasing down stuff too!
Reactions: kmq102 and Queticon
cliffish
TJ Expert
St James, NY, United States
yeah if you can't get a 2 or 4 post lift this is good way to go. I knew I needed 2 car storage so I did the 4 post lift, cost of the lift itself was about the same. Then it needs to be installed, chances are you need to lift the garage door tracks to a front torsion spring so that adds up.
