Snow? What's that?Haha! Our doors MUST open inward so we don't get trapped inside when it snows. You must be from Florida or something.
Agreed on not having a wood door. I don't want to take up the hobby of staining.
hopefully felt is behind the D Log siding to prevent water transfer. We like to fir out the siding for an air gap.
the osb and band behind it is getting soaked
The extent of damage can be from mild water stains to soft wood to termites and all about gone- and anything in between.
Worse case - You want to have a couple of days and good weather-
HAHA! Yeah, my apologies. I still haven't realized why, but I confuse you with Tworley (who lives in CO) occasionally. I would definitely fix that shit for a 12 pack if i was in your neighborhood. Lemme know if you need any more humorous promisesHave Jeep, will travel?
Don’t be at all intimidated- most people that are highly mechanically inclined like you make good carpenters- wood is just another medium.Wow. I'll be honest that 90% of those words mean absolutely nothing to me and that I'm about to start Googling them. Thank you so much!
If you don't mind some hand holding, it sounds like this is something I can confidently do. I'll even let you make fun of me when I ask occasional stupid questions.
Makes sense- I’d have some window and door spray foam for the door prior to interior trim, some plastic shims, some 3” torx screws for the door hinges, at least the top hinge, nail pullers like end nippers are great, some titebond 3 wood glue to seal end grain, and a level.I can't thank you enough @AndyG . This is all making a lot of sense in my mind now.
For a shopping list, it sounds like I need:
- Coated OSB to replace the parts I have to cut out.
- 2x8 and 2x10 to have on hand depending on what I find needs replacing.
- Roll of ice and water shield
- Roll of flashing tape
- Roll of zip tape (or is zip tape also called flashing tape?)
- Thin aluminum trim coil https://www.menards.com/main/buildi...m-trim-coil/999tbbl-10-14/p-1502260255744.htm
- New door. We need to look at a show room to verify we like it, but is one like this good? https://www.pella.com/shop/doors/entry-doors/fiberglass/glass/three-fourths-light/
- New trim boards
- At minimum a new deck board to replace the one closest to the house (and maybe cut down the existing deck to lower it?)
- New screen door kit. https://www.menards.com/main/doors-...27-c-6252.htm?tid=6533497098816889104&ipos=17
- Stain - Any recommended brands or types? I need to stain the entire house this summer too.
- 1/2" galvanized lags
- Caulk (what type?)
For tools:
- Miter saw
- Caulk gun
- Hammer
- Pry bar
- Table saw? (for trim?)
- Paint brushes for staining
Notice that I said window and door spray foam- it is non expanding and made for that purpose, plus it is closed cell and will not absorb water -spray foam.
Depending on how much rot you find at the sill/threshold (if any), you may need a sawzall to cut out the old one.
I didn't see that on your list.
They are great - slower but more accurate - good for trim- Milwaukee makes one that is a beast- used mine to cut out some subfloor yesterday because I wanted to accuracy more than speed-Good catch! I have a sawzall and circular saw already.
I also have one of those oscillating multitools — might be handy for cutting that old exposed osb out? I've never found a great use for it so I'm desperate to find a spot to use it. Lol.
That's it, all that's rotten has gotta go down to solid wood or foundation.Just like rust, you gotta cut it out. Hard to predict what you'll have to do though, until you get it opened up.
Do you guys remember the movie with Roseanne Barr’s husband where he was telling people to cut out bad wood and put in good wood- It was a pretty funny moment.That's it, all that's rotten has gotta go down to solid wood or foundation.
That'd be John Goodman, but don't recall the movie?Do you guys remember the movie with Roseanne Barr’s husband where he was telling people to cut out bad wood and put in good wood- It was a pretty funny moment.
Arachnophobia I think.That'd be John Goodman, but don't recall the movie?
This will not work for the OP, as he is in a snowy area... imagine what would happen if it snowed and drifted in front of the out opening door...doors that open OUTWARD. The harder the wind blows, the tighter the seal.
Tom Arnold...JOhn Goodman was her TV husband in the show. John has far better sense than to marry that train wreck of a woman, it seems.That'd be John Goodman, but don't recall the movie?
That is a water stain - what does it look like from underneath ? In the crawlspace . Hopefully it’s isolated -There's some discoloration on that first floor board inside the house, but it's solid and the appearance of it hasn't changed in 7+ years (when I moved in). Maybe just a stain?
