No water marks on the foam board that's attached to the concrete walls of the crawlspace.
I pealed back the insulation that's between the joists. Furthest back into the "pocket" there is faced insulation loosely pressed in there. I assume this is the area that's under the wall?
It looks like there's a line of white mold followed by black mold.
Does this mean I'll be replacing the flooring above it too?
I checked the opposite side of the house to see if it's an issue everywhere and it's as clean as can be over there. I've been wanting to replace the insulation that's tucked into those pockets with EPS foam board insulation cut to size. The idea being that any water that finds it's way back there can evaporate out through the board. Once I get all of this cleaned up is that still a good idea?
I do have a dehumidifier in the crawlspace and house both set to 35%.
