My completely stock 06 Wrangler with the 4.0 and NSG370 has been good to me reliability wise, but I'm getting up there in mileage at 172k and am getting worried whenever I have to take long trips. I've never owned a car with mileage this high. I think I've just about replaced all of the failure prone parts on these vehicles but if I'm missing something, maybe someone can chime in. Maybe I'm just worrying too much?
115k- Spark plugs, rear struts, rear sway bar bushes, end links ignition switch and actuator pin thing (preventative maintenance, heard these go bad easy)
116k- Thermostat, radiator cap, water pump, radiator, hoses, fan clutch, harmonic balancer, idler pulley
120k- OPDA replaced with Crown unit, transfer case fluid changed, transmission fluid changed, crank sensor replaced
127k- battery replaced
130k- Front and rear diff oil changed
135k- Replaced O2 sensors, replaced fuel pump (preventatively), replaced power steering fluid, replaced valve cover gasket, rear track bar bushing
139k- Rear u-joints replaced, brake fluid flushed, TPS replaced with MOPAR unit, cleaned throttle body and IAC
145k- Front pads and rotors, belt tensioner replaced
152k- Spark plugs, replaced both engine mounts, replaced PCM w/ wranglerfix
158k- Replaced front U-joints (preventatively), centering yoke, front sway bar bushings and end links
167k- Replaced tie rod ends, drag link, steering damper, track bar bushing
The Jeep drives great, no lifter tick yet, checked compression last time I pulled the plugs and it was good. I'm just worried because it's twenty years old and has so many miles but I'm pretty good about maintenance I think. Anything else I should worry about?
