I' not sure if my depth gage is junk or what but no matter how deep or shallow I set the pinion (Manufacturer spec say 2.261" from axle centerline) or how much I shim the ring side of the carrier my backlash reading has always been between 0.053" and 0.069" (which is absurd). The manufacturer spec is 0.007" of Backlash.
I set the depth gage up to be as straight up and down as I can get it without the ring gear rubbing on the back of the gage and I set the needle about mid way through its run on the tip of one of the ring gear teeth, then zeroed it out.
I finally gave up and did a tooth pattern reading, made several shim adjustments to the pinion and ring and here's where I'm at.
Compared to Jeeps Service manual tooth pattern diagram for the Dana 30 for my model year (1997), and the manufacturers tooth pattern diagram these patterns look very very close to me. Does anyone see anything that I'm missing? Any help or imput would be great at this point.
Drive Side
Coast Side
Drive Side
Coast Side
