The Mopar part is almost exactly double the cost of the off-the-shelf advance auto sensor.
Any known issues with those? I know they’re picky on other sensors.
it's pretty pathetic that aftermarket companies can't even get a TPS sensor to work. It's the most simple sensor in the entire system. CPS, CKPS, and O2 sensors I get because it has to respond very quickly and with precision but the TPS and MAP are basic transducers for which the technology has existed since Edison. I'm pretty sure the PCM learns the range of the TPS so they don't even have to be that precise as long as it stays within the range the PCM expects.
My TPS went out (06 TJ 165k miles), and as Autozone was close by I grabbed one there, then ordered a NTK off Amazon. The Autozone one died at the 2 day mark. I got the NTK one, and also order Mopar 4874371AD. The NTK lasted 1 day. The Mopar lasted like 5 minutes. I have now ordered two Mopar TPS's, part numbers 5019411AD, and 68404428AA. I figure I'll try all 3 Mopar TPS and maybe one will actually keep working. Why are there 3 different part numbers, all for the same TJ? What the heck is going on with that?
Pulled a no name TPS sensor off my tj and replaced it with a mopar TPS. The no name read acceptable using a multimeter, but my Jeep was jerky when coasting.
The mopar resulted in a smooth running coast.
Just my two cents
