T
TRE3TOP
Guest
Looking into a new synthetic winch line and came across these guys. Can anyone give me any feedback on them if you have it?
As above, TRE's winch line quality is superb and you can't go wrong with it. Still I have problems referring people to them after one of our own fellow Jeepers was forced out by after TRE was taken over by others.Looking into a new synthetic winch line and came across these guys. Can anyone give me any feedback on them if you have it?
That's a bummer, I really like TRE products and have purchased quite a few. I hadn't heard about the issue.As above, TRE's winch line quality is superb and you can't go wrong with it. Still I have problems referring people to them after one of our own fellow Jeepers was forced out by after TRE was taken over by others.
I’ll keep an eye on it whenever it gets it’s first use. It’s about as full as it was with the 100 foot steel cable, maybe slightly more. Nonetheless it’s on there now so it’ll have to do.Looks overfilled. Too much line can break the frame when the line bunches up on one side during off-center pulls.
Why exactly? What does likely going to suffer mean? Sounds like bullshit, just state facts, nobody needs more rumors.TRE quality of their aluminum parts is likely going to suffer after the next restock
there may be things you aren't aware of that don't need to be stated publiclyWhy exactly? What does likely going to suffer mean? Sounds like bullshit, just state facts, nobody needs more rumors.
The new line is 85 feet, the old cable was 100, but I believe you are correct on the diameters. So you’re saying you cut yours down to 65 feet?You likely went from 5/16" wire to the same length of 3/8" synthetic which increases the overall wound diameter. I've done the same thing but ended cutting 20' off to eliminate overfilled condition.
This explains the problems from overfilling a winch.
https://www.roundforge.com/articles/how-much-winch-line-will-fit-your-winch/
85 feet is correct. Has the rope been properly tensioned?The new line is 85 feet, the old cable was 100, but I believe you are correct on the diameters. So you’re saying you cut yours down to 65 feet?
There was tension on it when I spooled it up to get a nice and snug wrap. Or are you referring to something else?85 feet is correct. Has the rope been properly tensioned?
this is what Warn recommends:There was tension on it when I spooled it up to get a nice and snug wrap. Or are you referring to something else?
Looks like the rope is coming off of the top, but I’m sure it’s just an illusion.
It is, which I just read is the incorrect way, but that was the way the spool turned?Looks like the rope is coming off of the top, but I’m sure it’s just an illusion.
