Anyone know the type of nut for dashboard center studs?
AndyG
TJ Expert
Lifetime Supporting Member
Alabama
Southeastern NM, Roswell, or more specific, an area a bit south of Roswell out in the rural area in the midst of farming and agricultural. Lots of hay, alfalfa, corn, milo cultivated for livestock feed. Also why most of the dairies left California and landed in the same area. Cheap land with close proximity to lots of cow fodder.
Cool .
Mike the Silver TJ
Jacksonville FL
The 03 I just bought also has a noisy rattling dash. I guess I need to see where it’s bolted in and see if I’m missing nuts as well. Where exactly do I look for these missing nuts, I’m not real familiar with the Jeep yet.
You have to remove the defrost panel cover to see them. No screws in it, just automotive clips. Mine comes out pretty easy. It is item #1 below.
82441
S
Stockli
Fort Collins,CO
Thank you guys. Are they absent from the factory for a reason or just poor QC that day? Do any have them? I will toss some on and tighten the existing to see if it fixes the rattle. Washboard roads out here shake things loose.
mrblaine
TJ Guru
Quail Valley, CA
I've taken apart at least 12-15 dashes over the years and they have never been missing.
mrblaine
TJ Guru
Quail Valley, CA
Checked mine no nuts on the 2 center studs
I figured out the problem with those missing only two nuts. The anti-theft, anti-rattle brace to the back of the OEM radio is held in place with those nuts on the studs. If you have an aftermarket radio, the brace was removed and the nuts not replaced since they likely thought all it held was the brace and not the dash as well.
Reactions: Twopoint
Wrangler69
Oklahoma
Mine has the factory radio but that doesn’t mean somebody hasn’t swapped it at some point
S
Stockli
Fort Collins,CO
You may be right Blaine. I can’t remember if I took any nuts off when I swapped the factory radio. I can’t imagine i would not have put it back but it is certainly possible.
S
Stockli
Fort Collins,CO
Turns out I had a few nuts on hand that fit the studs. Not sure where they are from but they fit.
Snugged the other two up and it seems the middle two definitely tightened things up. I’ll let everyone know after driving if the rattle persist.
Mike the Silver TJ
Jacksonville FL
Makes perfect sense. The PO had an aftermarket radio put in at Best Buy.
