hi all, I’ve been giving some thought to a better engine in my TJ , it’s a 4.0 litre now , so the question ,has anyone swapped a 3.0 turbo diesel V6into a TJ ?
A V6 turbo diesel
If I was going to swap in anything, it would be a V8.
The 3L is in the JK’s over here, not sure if they do them in the USA, being common rail it’s a bit quieter than the old bangers, another thought is the ZD30 in our Nissan patrols, again common rail.A V6 turbo diesel from what vehicle?
The most common swap in our TJs in terms of diesels is the Cummins 4BT swab, which is a 4 cylinder turbo.
Diesels are too heavy for off-roading our TJs in my opinion, and the older ones are so damn noisy they'll rattle your fillings and ear drums out, especially if you ever go out with the top off and the doors off. I rode in one once and it was a nightmare!
Yeah, I was looking at a few engines , weight is a bit of an issue, I should just give the 4.0 a bit of work , cam, head , compression , and leave it fairly original.Your TJ will stoop down due to a very heavy V8 engine.
I did originally think of a LS3 but the TJ just don’t carry much fuel which can be an issue here
Nope, there’s a few good ones around, I was looking at the Hilux diesel as well , the common rail stuff adds some electronic hassles to the deal but they’re pretty economical, light and plenty of power around 170- 200 hpNot to change the topic but I have seen a suzuki diesel in Asia. That was a kick-ass little devil :devil-flip:
Have you taken a look at some mild to moderate 4.0 stroker kits?Yeah, I was looking at a few engines , weight is a bit of an issue, I should just give the 4.0 a bit of work , cam, head , compression , and leave it fairly original.
Keep the rebore to the minimum, 0.10 over for heat reasons. Now u have a new bottom end-throw in a valve job and u basically have a new higher HP 4.0
The 4.0L weighs 483 poundsYour TJ will stoop down due to a very heavy V8 engine.
Isn't the 5.3 Vortec V8 like 50 lbs lighter than the 4.0 liter?Your TJ will stoop down due to a very heavy V8 engine.
Actually we do! The 3.0 V6 diesel is available in the JLs 2020 and newer. And as for OPs question I haven't seen anyone swap one in yet. It probably would be a pretty nice option seeing as how it would use Mopar wiring, have more power than the 4BT, and have the benefits of modern fuel economy and quietness.The 3.0 Motori diesel from a Grand Cherokee or Ram 1500 would be a nice swap. Believe that is what the OP is asking about. We just don't get it in a Wrangler here, yet.
Shows how much I know about modern wranglers. I knew they had a diesel option, but did not know it was the same as the Ram and GK. Hear it's a good engine with a marine background. Has to be tough if it survives marine application running at WOT for days on end.Actually we do! The 3.0 V6 diesel is available in the JLs 2020 and newer. And as for OPs question I haven't seen anyone swap one in yet. It probably would be a pretty nice option seeing as how it would use Mopar wiring, have more power than the 4BT, and have the benefits of modern fuel economy and quietness.
