Well, as I mentioned in my og reply, I paid $60 bucks to have a shop run the wires. Its truly not as difficult as everyone here is making out to be.
There is in fact an OE wire harness that runs along the carpet (over the trans tunnel) and some of those wires eventually will be in contact w the aftermarket sub unit. But the stock power wire isn't thick enough (regulatory / safe, whatever its called) to power the Crutchfield sub. So thats why they provide proper wiring. The power is run from the batt to the sub, w a fuse in between (again, im not electrical authority) but this is why I preferred to have a shop do the wiring. Below is the raw basics:
1- remove console (you)
2- removed old sub from console (there's some clips and screws that you'll need to remove to take out the old unit)
3- install wire kit (I had the shop do all of that)
4- stand unit on its side
5- place console over the top
6- screw the console back in place (down onto the body)
7- enjoy excellent sound
At one time, (after enjoying for a year) I removed the center console to thoroughly vacuum and actually see the work this shop did, (they did a clean install) and it was easy to removal: unscrew, disconnect wires from the unit. I vacuumed everything and reversed the process w no issues. To expand- this is how I had the shop do the work: I left the center console gutted and removed (sitting in the Jeep) when I arrived at the shop for the install, I simply handed the tech the Crutchfield sub and wire kit and told them I wanted the sub to live inside the center console. And that's what they did.
Unless for some reason your console is different than mine, it will fit nice and snug. I have a 2001 TJ, w the sub console that has cup holders for rear passengers. Believe its a 'long console'.
Hope the above is clear. Chime in if you need more clarification.
Cheers [emoji482]
I have no worries about running the wires, I just wanted to see how much room it took up in your console and how it was secured.
Mine does not have the stock sub, so it would be a new installation. I already have a amp wiring kit hanging in the garage just waiting to be installed, somewhere. I have considered getting a powered Bazooka tube, but I like the idea of installing one of the "flat" subs in the console.
