Two issues:Seriously? I think we both have better things to do than this. I had a bad experience with the ethanol in the gas. Obviously you haven't. My point was the seafoam has been added to every tank of fuel and weather real or just luck I haven't had the same problem since.
1. it's a Sea Foam thread that you chose to bash ethanol in. Obviously I've got a vested interest in dispelling misinformation regarding ethanol use and effects.
2. You stated you use Sea Foam to make up for the lack of lead in the fuel. I actually burned the valves up in a tractor running a grain auger using unleaded fuel. I was advised to use a lead substitute in the future. I thought I should inform you so you wouldn't burn up your valves.
Apparently that part was missed.
Then you turned it into a personal assault...grow up, mommies basement, take a week to reply, and on.
I'm 55 years old. My mom has a crawl space. The house is rented and she's in a nursing home.
Perhaps I should have posted my age so I have more street cred?
And yes I do believe we both probably have better things to do!
However, I will continue to try and dispel misinformation when I see it.
