Which brand? How was the fit?I have the plastic ones. I like them with as much ingress and egress there is into my Jeep
I wish I knew, the PO had them on when I bought it. They are plastic. The fit is good. I haven't had any problems and people going into and out of front and rear seat area. With five kids you can imagine that's a bunch of in and out. I'll take a look and see if there are any part numbers visible. I'll take a pic too....Which brand? How was the fit?
Same hereYeah I’d pull them off. I don’t have entry guards on mine. It’s just plastic tape from the factory.
5 kids in a TJ?! Yer a madman!!!I wish I knew, the PO had them on when I bought it. They are plastic. The fit is good. I haven't had any problems and people going into and out of front and rear seat area. With five kids you can imagine that's a bunch of in and out. I'll take a look and see if there are any part numbers visible. I'll take a pic too....
Yer not kiddin! They have all been in it at once. They have little butts.5 kids in a TJ?! Yer a madman!!!
Yep- that's what I did on my old TJ. You can tape off a straight line to make the application look decent.I've considered bedlining the same area. Something to consider if you want to ditch them, but keep the protection.
Alright, there’s no markings on them. The PO got a lot of his stuff from Quadratec. They look like the Olympic, Crown or RampageWhich brand? How was the fit?
How do you like these? I bought a roll of stair tread tape but it is like sandpaper...not sure about it yet...then I saw your post with this product. How is it doing for you?I removed the old factory tape and used these: https://www.alphavinyl.com/shop/jee...angler/tj-jeep/wrangler-tj-inside-door-guard/
Funny, I thought just the opposite. I cut off the part that hung down outside the door. Much cleaner look.I like the kind that show maybe 1/2 inch of black after the door is shut. I think the contrast against the stone white looks nice plus it will cover the entry/exit scuff marks on my 21 y.o. tj
if your leg rubs that entry 1 bit in and out don't use that. once we get some good weather and your wearing shorts you'll know why.How do you like these? I bought a roll of stair tread tape but it is like sandpaper...not sure about it yet...then I saw your post with this product. How is it doing for you?
Still like them, and haven't had an issue. Once applied, no peeling up, etc. Just does what it needs to do. Still looks good too.How do you like these? I bought a roll of stair tread tape but it is like sandpaper...not sure about it yet...then I saw your post with this product. How is it doing for you?
