Does anyone know if the factory MOAB wheels that came on Rubicon TJs are cast or forged? I suspect they are low pressure cast (and pretty high quality at that) but I'm wondering if anyone knows for sure. They weigh 21lbs on my scale.
a quick googling shows JK moabs as cast so I'd assume the same for TJs
They are cast. High quality cast, but still cast.@mrblaine will know for sure. I always thought they were cast.
Pull one off, look on the backside where the stamping is that gives the pertinent info. Do you fucking see my name back there? No, didn't think so.So why are the 2006 style Moabs (with the ledges) lighter than the 2003 - 2005 versions?
How about the obvious answer? There is less material???????
How much lighter are they? I would guess less material as well. I've never seen anything whatsoever (including the original brochures) that suggested they were forged.
Did you mean to say that the 2006 versions were forged? Forged wheels would be lighter than cast.I would say a good 5 - 10 pounds lighter. Yet they are the same height and width, and they have EXTRA material in the ledges.
I suspect the 2003 - 2005 Moabs were forged, and then the 2006 versions and all the others that came after were cast. Why else would the 2006 Moabs be lighter?
I have a 2006 Rubicon with the original Moab wheels. I’ll have to look at the markings on the inside. I would truly be shocked if they were forged.
Forgings are generally much lighter because you can get higher strength with less material.Really? I always thought forged wheels would be heavier than cast wheels.
I checked the back of several Moab wheels I have here. They all have a mold number on them. They do that to track mold damage so they can fix it.In most cases a forged wheel will be lighter than cast wheel as Blaine said.
Forged wheels are also generally much more expensive than cast wheels.
I will leave the door cracked just a smidge since I don't know for certain that I have all examples here.I guess that puts the forged idea to rest once and for all.
