TJ Fest 2021
Are my LED headlights installed upside down?
notlohdahc
Colorado
Are my headlights upside down? They cast a weird light above where they should be shining. See images.
pagrey
Los Angeles, CA, USA
It's difficult to tell with that beam pattern. I'd just aim the top edge of the hot spot about level and see if you irritate people.
TJTJ04
Southeast Texas
The top and bottom row of lights are the main rows of LEDs in your headlights. In the middle of your photo is your low and high beams. The brighter area. You also have an extra wire for daytime running lights that you can tie in to your clearance lights.
rasband
LJ Enthusiast
Highlands Ranch, CO
I have the same lights, so this isn't meant as a dig. However, I just think they are fairly low quality and get weird reflections. If you're unsure, the pigtails come out of the bottom on the backside from what I could tell.
Chris
Administrator
Staff Member
Florence, Arizona
In my experience that design of LED light is one of the lower quality ones in terms of light output. I tried them out for a brief while but returned them as I didn't care for the light output of them compared to the Truck Lites. I'm not sure there is a right side up or upside down to them honestly.
Reactions: AustinJeepTJ
AustinJeepTJ
♪~ ᕕ(ᐛ)ᕗ
Washington
I had these. Couldn't get them dialed in to save me. Struggled for two-ish months. The beam was to focused and my eyes weren't able to adjust. I went back to H4's in a set of KC hilites.
notlohdahc
notlohdahc
Colorado
I bought the Jeep this way. The previous owner installed them or had them installed. So they very well might be cheap junk.
I wasn't sure if this was normal for these lights or not.
I thought that they are in upside-down and the weird light, up high, should actually be pointing towards the ground.
notlohdahc
notlohdahc
Colorado
I bought the Jeep with these lights already installed. Sounds like I should add headlights to my list of future upgrades.
