The new mounts are in and the results are astounding. It feels like an electric car compared to the way it was. Idle vibes are gone. Floor board vibes I was getting at varying rpms are gone. The Jeep is overall much much quieter at all speeds and just plain smoother to drive. Mopar mounts are the way to go.
I also trimmed the frame bracket for the mounts because the motor bracket and frame bracket were touching. Getting a grinding wheel in there was a bitch so the cuts aren’t beautiful. But I have lots of clearance there now.
Sounds like the rough country lift blocks are already cut and clearances for the bolt head on the passenger side. I think some other brands you need to trim the lift block to clear
When installing motor mount lift blocks like this, don’t forget to cut the motor mount studs enough that the extension bolt fits snug against the motor mount. I cut about 1/4” off with a cutoff disc, then used a filed on the edges so it would thread on nicely, then some red loctite.
