Let the air out of the tire, remove all the bolts, check them for damage, buy new ones to replace the fucked up bits, pop the outer bead with some air, break the inner down, remove the tire, while tire is off check all the threads in the bolt holes, install new tire, bolt ring back down, air up tire to seat bead. Lest we forget, bead lock bolts are a maintenance item, the air needs to be let out of the tire and the bolt torque checked at least a couple times a year. Or if you notice any backed out, with at least that much frequency.
All the bolts need to have very similar loads on them since the force from an inflated tire trying to blow the lock ring off is very high. Compromise a few bolts next to each other and a catastrophic zipper effect of popped off bolt heads can occur.
Also why you need to check torque with the air out of the tire.
