We sold the house and going camping in the Jeep,it’s starting to squat down in the back,I could correct it with spacers but don’t want it high in the rear when we are unloaded,pondering what to doWeight distribution hitch ?
Go forth and use levelling bags if you wish! But to tell you the truth I have over weighted overlanded my TJ with zero problems! Lets look at the weight of an average westerner in the back of a TJ, at least 80KG = 176 pounds each rear passenger to which jeep allowed for! If you are loading more than 250LBs in the rear of your TJ you should consider Motels instead of a camping road trip lol
If these things go into the spring what do you do about the bump stops,I would just add spacers but when I get done loading it,I don’t want it to be all high in the back,anyone have any ideas?thanks
I ran air bags for leveling in my Cherokee and Grand Cherokee so it would ride level with my boat trailer's tongue weight on it. They worked great.
I have the air lift on my dodge and they work great. I think the recommendation is to leave 5 psi at a minimum. Like someone said earlier, if you empty them they would likely get damaged. I don't really notice when they are at a lower psi but can tell they help when trailering my jeep and aired up.
I'm not sure how it would be set up on a jeep since the valve is on top with the air line going to the bumper.
In the same way a semi truck runs air bags.
I dunno anything about them. How is that setup differently?
