Atlas shift indicator
Akitadog
Willy's Edition
The "209"
Well reading thru the guide it says to install the TJ shift indicator, but does not show where that will be.
I found a threaded plug on the back under the rear upper protruding part and was wondering if this the right location?
If not then where? Do i need this shift switch?
B00mb00m
The Church of Cutting Brakes of Atlas-Front Digs
Washington
The left one there will tell you when the front drive shaft is engaged or not, so essentially 4wd or 2wd, but it will show 4wd during a front dig. Have you heard the good news about front digs?
Akitadog
Akitadog
Willy's Edition
The "209"
I suppose I could run two is series, that way when both are in low it will be 4wd....
I've seen front digs done.
Reactions: B00mb00m
