Jeep TJ 2000 4 Banger
I'm going to list my symptoms and what I've replaced, let me know if you can suggest what might be the problem.
So I recently had a newly rebuilt engine put in and had basically everything inside replaced. So my guess is that it is a wiring issue instead of a gear/mechanical issue.
Symptoms:
Idle's perfectly
When accelerating and getting to about 2000-2500 RPM my gauge begins to bounce up and down, when trying to accelerate it stays in that range bouncing between 2300- 2500 RPM and the UP Shift light indicator flashes on when accelerating and turns off when decelerating.
The Jeep seems like it doesn't want to shift into a higher gear and hesitates in the same spot continuously until It starts going downhill to gain more momentum.
Please let me know if you find anything
Symptoms:
Idle's perfectly
