Auxiliary brakes for TOAD TJ?
Moglocker
Missouri
Wiring the towing lights on the TJ and gonna put the emergency breakaway braking device on but everyone I talk to tells me they don’t use the aux brake system at all.
Moglocker
Moglocker
Missouri
I know,everyone says they use the brakes up fast,Missouri is the only state that don’t require,I guess put on the ready brake to keep the lawyers happy lol
Viking Jeeper
2A Supporter
Jacksonville FL
What are you towing with? Laws and insurance aside, actual safety will be much different if you are towing with a 1/2 ton truck vs a diesel pusher motorhome.
Jake21
Santa Fe, NM
We are selling Everything and diesel pusher for a few years
We have been full timing in a 40foot DP for 9 years now. We tow a TJ without an aux brake. Have logged over 100K on the road this way. I don’t notice any difference between towing and not towing. With or without a aux brakes, you need to drive at least 1/2 mile up the road. I always run google maps when driving, especially in the cities. The map gives you (sometimes) a heads up when a slowdown is in your near future. It helps. I have a Roadmaster tow bar and a 10K LB rated hitch.
What DP are you looking at?
Onetime12
Downey, Ca
I just recently started towing our 99 TJ with our 36 foot DP. Using a Genright steel bumper, Blue OX tow bar and emergency cables. I have not purchased a braking system, I can feel a slight difference in breaking but nothing dramatic. Everyone's advice for the added braking is valid and I will be adding, but for the (3) 500 mile trips we had no issues.
Mr. Bills
Raconteur Emeritus
Area Code 530
I know,everyone says they use the brakes up fast, Missouri is the only state that don’t require, I guess put on the ready brake to keep the lawyers happy lol
The lawyers and the insurance companies.
State troopers too.
Like it or not, and diesel pusher or not, it is the law in every Canadian province and in all but two states for a flat towed vehicle the weight of a TJ to have an auxiliary brake system.*
I use an RVibrake3. This thread might be useful:
* MO and MA are the only exceptions in 2021.
Moglocker
Moglocker
Missouri
365 rv-Sportscoach bath and a half?
Farmergreg
11.8750 isn't 12
WC Indiana
I bought a used Brakebuddy system on marketplace to satisfy the authorities.
Inertia activated, air piston pushes the brake pedal, sits on the floor, seat slid up to keep it place. Hasn’t given any issues.
rancholago
CA
I have the "ready brute elite" by NSA its a surge type supplemental braking system. Tow with a F350 and Cabover camper. Son in law tows his with no supplemental braking system. For me its a comfortable thing, plus legal CYA
Steel City 06
TJ Expert
Pittsburgh, PA
I installed the Brake Buddy Stealth on my TJ. It fits perfectly in the gap between the seat and the edge of the tub. It takes a bit of time to install, but once installed all you have to do is connect one plug, press a button or two, and you're good to go for any trip.
I did purchase a better vacuum pump than came with the kit. The Stealth doesn't have the power to lock up the brakes, but it certainly makes a big difference when it kicks in. It also includes a breakaway feature as required by law.
alittleoff
I find it easier to comply with the law rather than explain to a Judge why I didn't.
So that's why I tow the Jeep on a tandem axle trailer with brakes on both axles.
Safety first... and just my preference.
SoCalGlide
FOG
The 'Nard
3500# seems to be the magic number for most, but not all, states. If what you're towing, be it a trailer or flat towing a Jeep, weighs more than that, you're supposed to have a supplemental brake system with a break away switch. I use a simple Brake Buddy Classic to tow my LJ. If you set it up correctly, it will work without issue.
