TJ Fest 2021
Awful clunk on uneven right turns
jkimm7
Rhode Island
This has been driving me nuts, Whenever I take a sharp right turn or turn right on an uphill or downhill, there is an awful clunk that seems to come from the back end. I have recently installed new shocks, new sway bar bushings and sway bar end links and still cannot find where the sound is coming from. I cannot replicate the sound parked or jacked up. Some of the control arm bushings are starting to show some dry rot but are not visibly worn. Would control arm bushings be the cause of this or produce a sound like this? the sound doesn't seem to be metal on metal but a much lower clunk (unfortunately that is as best as I can describe it) I have checked the play in the rear axle c clips and it is within the normal amount of movement. I do have 1.75 inch coil spacers if that might cause some original parts to be maxed out. Any suggestions are appreciated
I have to ask, have you checked the frame at the control arm mount for rust? Very common on a tj. Track bar bushings?
Sent from my SM-G930V using Tapatalk
Reactions: TJBob
J
jkimm7
Rhode Island
Forgot to mention that I have a new frame so there’s no rust there, I will check on the track bar bushings as soon as I get a chance
Reactions: MaloStapalo
TJBob
South central Indiana
I read on here awhile back, about how it’s good practice to loosen up control arms and re-torque them once in awhile, with the vehicle on the ground. Something to do with coil springs settling over time and binding the bushings on the control arm. Idk if this would cause the arms to pop or clunk, but it could be a good place to start since you have the spacers.
Maybe one of these guys that has a bit more knowledge than I do will chime in for ya.
I had a mysterious clunk I chased for awhile. Turned out to be the rear sway bar end link on the driver side. The upper endlink bolt had worked its way loose. You said you have replaced all of that. May go back and double check torque just to be sure you didn’t miss a bolt.
Good luck!
DetroitTJ
Detroit, MI
Do you have some form of limited slip differential in the rear? Could cause this type of noise with quick turns.
J
jkimm7
Rhode Island
No slip diff in the back, the axles were replaced by stock '06 axles but were identical to the original axles
toximus
TJ Expert
Northern WI
Find a diagram online and check that all of your body mount pucks are in place.
Do you have a body lift?
Alex01
Enthusiast
Martinez, CA, USA
Good luck!
X2. The first thing I would check it the torque on the control arms. Every so often I hear a clunk in the rear end and so far every time the issue has been that my passenger side lower control arm needs to be re-torqued. In my case I usually hear a clunk if I quickly smash the throttle and let go. (think a bucking bronco).
Can you simulate the noise by pushing the jeep really hard side to side or jumping on the rear bumper?
J
jkimm7
Rhode Island
I will try re torquing the control arms, can't replicate it by jumping on the bumper, I will try side to side soon
DaveC
Gilbert, Arizona
I had the exact same issue. TjBob's comment is right on
....rear sway bar in mine as well.
Mike_H
Rust Belt Heavyweight
I had a mysterious clunk that I chased for a bit. Couldn't replicate it by jumping on it, shoving it side to side, etc. Only while driving. It turned out to be a control arm bolt. I finally gave up and took it in. The Mechanic hit them all with an impact, and broke the one that was loose. Apparently, it had been stretched and was not holding torque anymore (as I torqued it when I put it in). It was probably right on the edge of breaking when I finished. Just took another check to find it.
Shinebox_LJ
Los Angeles, CA
Is that common? I recently took mine to the shop for a mess of noises (bent axle, control arm bracket, and the slip on the rear 44 was no good.) I replaced it with a truetrac but hear that clicking noise on sharp right or quick turns. Sometimes on left as well. They told me at the shop (who only work on Jeeps) that it’s the slip. They checked the slip again and changed the gear oil after 500 miles and said everything looks perfect. Other than the click, it rides like a champ. It wouldn’t get to me as much if I knew that’s what it is lol
DetroitTJ
Detroit, MI
Is that common?
I honestly don’t know if it’s common or even a concern. I had read before that a LSD can cause a clunk when taking corners and it just got me thinking I guess. It makes some sense that if the differential locks especially on a vehicle with oversized tires while cornering, that there would be unfavorable stresses across the rear end. Ideally the differential would be open while cornering. When I posted that question I was actually hoping to get some affirmation that this could be the case.
Let’s ask @Rob5589 - he’s very knowledgeable about gearing.
Rob5589
Certified video trained differential rebuilder
W Sacramento, Kalifornia
A TT should be silent. There is nothing inside to "click" together like a true locker. If on the gas hard in a turn you may get a tad bit of tire chirp but it shouldn't click.
Reactions: Shinebox_LJ
