My guess of a typical clutch install is $600 or so. Replacing a clutch isn't technically challenging but it's definitely a most-of-the-day job for anyone inexperienced and not in a race. No special tools are required, other than an E-10 and E-12 reverse torx adapter to unbolt the transfer case from the transmission and transmission from the engine. A transmission jack makes the job a lot easier. There's not much to go wrong other than it can be tricky to get the transmission perfectly lined up so it pulls free or can be reinstalled.
If you have a good set of basic 1/2" drive size hand tools and a jack, it's not a bad job for anyone willing to get their hands dirty. There's no adjustments, you just unbolt things and bolt new replacement parts back into place. We can walk you through it if you decide to tackle it. Heck I was nearly 60 and already tired & achy when I started my previous TJ's clutch job. Luk makes the best clutch kit so far as I am concerned and the good news is they are inexpensive on Amazon.com.
http://www.amazon.com/dp/B000CICZ1M/?tag=wranglerorg-20.
One last comment, no need to pay extra for Luk's 'Pro Gold" clutch. The Pro Gold is made for trucks and is noisier without any benefit like longer wear when installed into a TJ.
