M
motomick76
Guest
Update: Put axle together last week and still have noise. Today I put it up on stands, and what I thought was coming from axle was coming from my transfer case. Sounds like I need a set of bearings for the case, a rebuild kit. Issue is, who has one, or who has rebuilt one, and where did the kit come from. I have found a couple different kits, but nothing definitively saying they are for a JK241OR case. I have found two, but have subtle differences in the pictures:
Transmission Parts Distributors - NP241 or NP241J
Allstate Gear - NP241J
Anyone here know what to look for when getting a rebuild kit?
Decided to take an extended drive around Mt. St. Helens this weekend and in the 700 miles driven, noticed a noise from rear axle. It was readily apparent on long uphills pulling hard, and downhills using the engine for braking whirring sound. Also from a stop taking off, I can hear and feel in the shifter, best I can describe it as a tick, and speeds up as I accelerate. Confirmed it was rear axle as removed driveshaft this morning and drove around block with front axle engaged. No 'tick' and a lot less whirring sound.
A little backstory on axle:
Got digging this afternoon, and pulled axles out and carrier. Could not find anything significant.
- Detroit locker
- Revolution 4.88 gears
- New bearings, axles seals, everything in 2015
- Driven approx 2,000 miles total since rebuild
- Pinion - Tight, still preload drag on bearings, and spinning it feels smooth
- Carrier - Bearings and races appear great, spun by hand and cannot feel anything
- Pattern - i do not have enough experience to give opinion on the pattern or gears
- There is metal in the oil, as seen in the pictures
- How is the pattern and gears? Is this abnormal or normal wear?
- What steps should I take next to determine noise and correct?
