So after an accident when I was rear ended straight on my rear right wheel I had to change the axle shaft which was bent.
The thing is, the bolts provided to hold the axle shaft make contact with the disc brake plateau and make a creaking noise.
Thoughts on trimming the bolt heads to solve the issue or it will make the shafts’ unstable?
