I'm getting ready to make some upgrades, including: big brake kit, rear axle to 30 spline, and gears to 5.13. I would like some help validating my parts list. So, I've listed my current jeep, my changes, and a parts list. I've also listed some things that I studied and decided I don't want. Can the experts here help me to validate the parts list, point out anything I missed, and any other feedback?
I wheel in SoCal in and around Big Bear.
Current Jeep:
Current Jeep:
- '05 Jeep Wrangler X
- 4.0L Motor
- 42RLE Autotrans
- 2.72 Transfer Case
- 35" tires
- 4.88 Gears
- Front Dana 30 has 27 spline Eaton elocker with Revolution 4340 Chromoly Axles and Stock Brakes
- Rear Dana 35 has 27 spline Eaton elocker with Revolution 1541H Axles and Stock Brakes
- Front and Rear: Re-gear to 5.13 final drive
- Front: upgrade to Black Magic Brakes 16" Big Brake Kit
- Rear: Upgrade to 30 spline Eaton elocker with 30 spline Revolution 1541H Axles
- 5.13 Revolution Gear Set
- Black Magic Brakes 16" Big Brake Kit
- Revolution 1541H 30 spline axles
- Eaton 30 spline Spider Gear set for a Dana 30 elocker
- To Convert my 27 spline elocker to a 30 spline elocker
- Dana 35 Master Rebuild Kit
- Because I'm pulling the carrier to regear and respline
- Dana 30 Master Rebuild Kit
- Go down the aftermarket Dana 44 rabbit hole to get 5.38 gears
- This is somewhere in the $12000 range...
- Maybe if I ever want to go 37's
- Or, If I really need 5.38 gears over 5.13 gears
- Truss my Dana 35
- Several threads here indicate this is not needed
- Truss my Dana 30
- Gusset my Dana 30
- Seems to be a JK problem, not a TJ problem
- Buy a new Eaton 30 spline Elocker
- I can update instead of buy new
- Change to RCV axles
- While this would be nice, it's also expensive, so maybe a future update
