Man am I getting frustrated here and some of you are very competent in CB's and comm's so my question. I have a fairly new Midland 101LWX, Firestick 4' antenna and using a Firestick "fire ring" coax. I cannot get close to acceptable SWR reads and Ive relocated the antenna twice. The Fire ring is mounted on the bottom of the mount,sholder up into the mount hole as well. Ive ground off any coatings to bright metal and have good connections. Im using a Astatic PDC1 meter to tune. Set the switches,key the mic and set the meter needle to the "set" position,all the way to the red #10 area. Flip down the FWD/REF and I get 6'es on the swr give or take, on CH #1 or CH#40.
Tuning the antenna yields some change but nowhere close to 2's. Understanding Grounds are critical I cannot understand this part. With the Fire ring cable on the work bench and the CB end removed (RFU501) and looking at clean separated inner and outer copper I can OHM the cable from the center metal ring on the fire ring end, which touches the ground/mount, and get O ohms touching either the outer braided copper or the finer inner wires. This in a nut shell is grounding out both inner and outer parts of the coax. Can this be correct??
Please steer me in the right direction here.
