I want to start this thread now so I can organize everything I want to do with Barbara. While she does turn heads as she is being as close to stock as you can get without being stock I am going to give her the love and TLC she needs to turn her into an off-roading babe. I plan to be posting pictures and little guides to everything I do. I will also be posting any other things I do with Barbara like trips and questions. So this is what I am starting with:
To give you the run down I'll start with my capability goals with Barbara.
- She will be able to rock crawl
- She will be able to overland
- She will also be my daily driver so comfortability is a must. (mostly an interior thing)
- Now here is the tall order... I want to keep her from looking crazy modded. The closer I can keep her to stock look the better.
- I want a full engine compartment rebuild/refresh. This is for peace of mind and the fact that she is 18 years old with 150k miles on her. I'm sure Barbara needs it.
- 1.25" body lift
- 1" engine lift
- Tummy Tuck
- 4" Short Arm Suspension Lift
- Going for a gear ration of 4.56 or 4.88.
- Change the fenders to accommodate bigger tires and more clearance.
- AR or ORO Sway-Loc (for better off - road handling)
- 35’s AT (If this is a daily driver or for better highway manners choose some good all terrains)
- On 17” aluminum wheels - For bigger brakes and better tire selection than 16”
- SYE - Required for lift and TT
- Double Cardan DS - Again required
- Dana 44 Rear - will work just fine with axles and a locked
- Dana 30 Front - will work just fine with axles and a locker
- 1” BL - required for TT or to run 35’s
- MML - required for TT
- TCase Cable shifter - required for TT
- New sound system (I already have new sound bar and dash speakers but I want to add a subwoofer and amp still)
- Interior and exterior lights
- Winch/Recovery gear
- New rear bumper and tire rack. I want to keep the front bumper and just make adjustments to strengthen it up.
- CB and Ham Radio (maybe ham)
- Air Compressor
- Upgraded the Radio.
