Pennsylvania Battery cables
Feralkid
Medicinal Crack Cocaine
SE PA
Price
Cost + shipping
Pa
Got ahold of a nice battery cable crimper.
I’m offering custom battery cables at cost + shipping to forum members until I get bored or start wanting to make money.
Pm me with your specs and I’ll get back to you with a quote.
Reactions: TRE3TOP
Pm me with lengths, guage, color(red/blk), terminals(straight/90, 5/16 or 3/8) etc...
And I will give you a quote
Reactions: JMT and MikeE024
I've been looking at making some myself for mine but never got around to it. The kits I've seen look too long and would leave a lot of loose cable buggering up the engine bay. I think I'm going to take some measurements and get with you soon. Thanks for offering this!
View attachment 324050View attachment 324051View attachment 324052View attachment 324054
Can you share what crimper you are using? I need one and I'm not in the cable business so I won't compete against you. Great choice on wire as well.
Anyone know the OEM length for TJs? I would love to get a set
Looks like 06 would be a little more complicated than just lengths. The positive batt terminal has two wires out of it; a short one to the PDC which has a wide tab for two studs, and then a longer one down to the starter. The negative side has a cable down to the block and one up to the firewall. If I get some time tomorrow I'll try to get measurements of all of them.
I don't remember if my 99 was setup the same way. I do know it had big solid lugs instead of the thin stamped ones my 06 has.
Is there a problem with existing wires? I’m not sure that all of them need to be upgraded. And I would prefer measurements and so on for your custom circuit. Don’t just mimick factory. What kind of fuses should be used? I was thinking mega fuses.
If you have other projects like solar chargers/inverters I can produce cables from 10AWG to 4/0AWG.
I was just responding to his question about getting replacements for stock. Mine are just fine, but if I was replacing them I would at least want to match the tab on the PDC.
