Battery terminal contacted edge of tub, TJ exhibiting weird driving behavior afterwards
This is exactly what I have been looking for. TU...
YW!!! I do like that it comes with a choice if you have different gauge wires. EZ to change and just what I needed! Also installed the dorman battery hold down. Battery is secured NOW!!
Be overkill and install a battery cage like I did😆 Problem solved....I like to drift and do donuts alot,crawling etc. (alot of spirited driving) so I just went ahead and pulled the trigger on a odyssey battery and a next venture motorsports cage
Didnt wanna risk frying my new WF Pcm so with bigger reason i did this,overkill? Yes! But i want it to be that way in this case,I used to get occasional flickering on my dash when I first had the batter arc out on me but over time it gas gone away thankfully!
"Old" (1yr.) pic for reference,you can kinda see where I arced out my fender and did a shotty attempt to "fix it" with electrical tape.....
Edit- as of now I'm running "Knukonceptz" battery terminals that allow slick installation of Audio related stuff (anything really) and a nice place that allowed me to cleanly hookup my winch 😁
  • Wow
Reactions: CES22
Personally I've used them and they suck. Crimp rings on the cables and use milspec posts.
-Mac
Links please...
These showed up today. I am trying to figure out how to cut the battery cables clean to
facilitate using the connectors. I know I will using NoLox on everthing.
