There seems to be a design philosophy common in Europe that results in recommendations of higher viscosity grades like 20W50. I don't know whether the difference lies in oil pump design, volume flow demands, bearing clearances, or all of the above, but despite being an inline 6 and briefly being owned by Daimler, the Jeep 4.0 isn't the exact same thing as a BMW and it shouldn't be assumed that they have anything in common beyond their cylinder orientation.
Shell Rotella T4 . . . 15W-40
Good product.
Applicable to your situation?
I run it in both 6BT Cummins, and also in both Honda 450 Foreman quads.You can't put diesel truck oil in a Jeep I only use it in my motorcycles and law mowers.
This is why I asked on here, we have a minute amount of jeep 4.0,s compared to US and perhaps the thicker oil is killing them quicker or the thinner recommended oil is killing them quicker in high temps?I live in the tropics, hot weather all year round and would not even consider running 60w oil. That weight is just to thick, I've seen 40w with high mileage engine, but at 60w it might not even lubricate the engine propperly. In an earlier post you mentioned that 100K is when most cars will go to the junkyard. It is a known fact that the tj can make it to 200-300k. If they are all using 60w oil for the Tj's there might be some correlation to the time the engine blows and the kind of oil you are using over there.
The start up issue would only be an issue if you're running conventional oil in super cold temps.This is why I asked on here, we have a minute amount of jeep 4.0,s compared to US and perhaps the thicker oil is killing them quicker or the thinner recommended oil is killing them quicker in high temps?
High mileage oils here all seem to be 15w 50 and now its been explained added Zink cant make a 40 viscosity a 60 as I was previously told I wont use it as I have never considered a 60 weight oil before plus after reading up on viscosity from 4am this morning (yes sad I know) a higher viscosity could make my start up lifter rattle worse.
So its my fault my 06 made a one time presumed squeal from my OPDA and immediately changed it when every man and his dog shits themselves about possible OPDA problems?OP, be honest, have you tried this mystical 20w-60 ?
If so, this will explain your previous posts about reliability of 4.0, engine noise and opda ...
Why are you on the forum asking what to do if you are just going to go with a mechanic or whatever you want anyway?Lots of piss taking here! how many mechanics here or oil experts? the Penright HPR 20w 60 is a mineral oil for high mileage engines commonly use in Australia the 60 rating is upped from 40 to adjust for the high zinc content in the oil.
Just because somebody has never varied beyond recommended 10w-30 doesn't mean anything other than they stick to manufacturers recommendations! Anyone would think 20w-60 was as thick as Molasses or treacle judging some comments but difference couldnt even be told by a layman visual or touch test.
the mechanics I speak to shake their heads just as much at the forum concerns I bring up over using a heavier oil and that I must stick to 10w-30.
If you read the whole thread the hair on the back of your neck may settle a bit? lolWhy are you on the forum asking what to do if you are just going to go with a mechanic or whatever you want anyway?
I read the rest quickly. I wouldn't worry too much about what oil, but perhaps something less radical a jump between 10w-30 and 20w-60. I have no user experience other than 10w-30If you read the whole thread the hair on the back of your neck may settle a bit? lol
Where did I say I had decided ? I posted on here for opinions after advise was given. staunchly sticking to10w 30 may just a be a little bit of Cognitive dissonance! lol
Can not comment on the Rotella but I have run Delo 400 in the summer up here and the ole 2.5 did not complain.Shell Rotella T4 . . . 15W-40
Good product.
10w 30 is not a common oil in Australia and my last change to 10w 30 I had to buy a more expensive oil for high performance engines and when you can find it its either fully or partial synthetic..I read the rest quickly. I wouldn't worry too much about what oil, but perhaps something less radical a jump between 10w-30 and 20w-60. I have no user experience other than 10w-30
How about 10w40?10w 30 is not a common oil in Australia and my last change to 10w 30 I had to buy a more expensive oil for high performance engines and when you can find it its either fully or partial synthetic..
I can get 15w 40 easy even from Kmart!How about 10w40?
The 4.0 does not need synthetic. If you can get conventional 10w-30 it will work just fine.10w 30 is not a common oil in Australia and my last change to 10w 30 I had to buy a more expensive oil for high performance engines and when you can find it its either fully or partial synthetic..
