I have a 2003 TJ Sport, 4.0, NV3550 trans (I think), Dana 44 with disc brakes in the rear with an ARB locker, 33 x 12.5" tires and a 4" lift. I came off the freeway a couple of weeks ago into one of those long winding 90 degree off-ramps. It was wet out and I was not going very fast due to that. But, the rear let loose anyways. I came around and the passenger rear tire made contact with the curb. It hit the tire right at the rim and de-beaded the tire temporarily, long enough to allow half the air out before resealing. I can see damage to the rim at that point. I ended up in a field facing the road I just came of of. I popped it into first and drove back onto the road and back home, which was quite close. I jacked up the Jeep when I got home, removed the wheel but didn't see anything obviously damaged.
When driving my Jeep later I could hear what sounded like a rubbing sound coming from back there at low speeds. I removed the wheels again and put a dial indicator on both axles. The driver side shows 0.005 runout and the side I hit shows 0.040 runout. I looked carefully and can't see any physical rubbing of anything. Am I being over cautious here? I will have to wait until after winter to replace the axles as I will be doing this outside in the driveway (snow). So, I will keep my Jeep just around town until the end of the season. With what I've stated, am I going to damage anything by using it until I can fix it?
I'm looking at these Revolution Gear axles which are about 2 months out for shipping. My Jeep is a United States Jeep which I imported into Ontario Canada when we moved.
A Dana 44 is a Dana 44 is my guess, Canadian made Jeep or U.S. Jeep. Since I would be buying the parts here.
Are Dana 44's generally 30 spline?
Does knowing the exact model of transmission have anything to do with the fitment of these axles? They ask on their site.
I live in a rental house with a tiny garage, no vice. Can anyone think of a way to torque the lug bolts that come with the axles with limited tools, 95lbs? Pretty much hand tools only. I can't see a way to get a torque wrench behind that axle when mounted.
Thank you for your thoughts.
