Assuming you are set up for 37’s.35s BFGoodrich Mud Terrains
So basically the same conversation your wife has with her girlfriends about you?I found were MTR can be hard to balance and KM3 might run a bit small.
Not many of us here care or are impressed that Daryl is running 37's on the factory axles. Few knowledgeable (!) Jeep builders would ever say 37's are ok to run on the TJ's Dana 30 or Dana 44 axles. It's not a matter of uf that size tire will cause problems like for the ball joints, it's when... at least if the owner is driving with them on trails that require 37's. Mall crawling? Sure, those axles will last longer. Good idea? Nope.@Daryl has been successfully been running 37s on his jeep with stock axles and I can assure you he has gone on tougher trails than I have. While larger axles are ideal the way you drive will have the largest impact on longevity.
Small but with a great reputation!So basically the same conversation your wife has with her girlfriends about you?
Yeah debating either MTR's or KM3s. I have KM2s MT 35in on right now but they are not the best on snow. How are the MTR's on snow/rock/highway?I like my 37X12.5X17 MTR’s they work pretty good up here
The KM3s & MTRs are the ones im kinda leaning towards, here we have rock, snow, mud and highway. I currently run the KM2s but not the best on snow so wondering if KM3s might be betterCurrently running 37 milestars and for a Pnw tire I'm looking at moving to a MTR or KM3. An AT tread around here will definitely pack up with mud so MT is required for wheeling IMO. Both KM3 and MTR have solid traction v noise reputation. The internet complaints I found were MTR can be hard to balance and KM3 might run a bit small.
Yeah KM2s are pretty badass, just not good when it gets icy. KM3s have great reviews so leaning towards that. Thanks! & yes setting up for 37s.I really liked the 33" KM2's I had on my TJ for years. Lasted a long time, did great in rain, pretty good in snow, and held their own in mud. I'll be grabbing KM3's next time I change tires. I switched to Maxxis Trepadors from the KM2's and do not like them at all.
Also, make sure you are set up for 37's. If you have stock axles, do not run them.
Good luck with that.... yes setting up for 37s.
