I want to put a 4 inch lift on my 2000 tj and was just curious what lift y'all would recommend that's not crazy expensive but still handles well
I want to do occasional wheeling but I do drive highways a decent amount so I'm not trying to buy a awful lift that destroys my jeeps rideWhat are your plans for the jeep?
Sent from my SM-G930T using Tapatalk
Thank you very much ill look into the liftWell, most people seem to agree that the best high end lifts (4") for the TJ are Currie, Savvy and Metalcloak. I run the Currie 4" lift, and just like the Savvy lift (which is essentially the same), it is indeed the Cadillac of Jeep lifts. It comes at a high cost though, that's for sure.
Stay away from Rough Country and Skyjacker, as well as any of the no name brand lifts. Those WILL DESTROY YOUR RIDE in terms of ride quality. They are cheap, but there's a reason they are so cheap.
The unfortunate truth of it is that I don't think it's possible to do a 4" suspension lift without spending at least $2000 or more, all while expecting a good ride quality.
I think your best bet would be to get the OME 2.5" lift (which is an outstanding lift and priced reasonably too) which will put you at 2.5" of lift. Add on a 1.25" JKS body lift (which also sets you up nicely for a tummy tuck in the future, if you want one), and you're sitting at 3.75" of lift. It will look good, fit 33" tires comfortably, and ride like a Cadillac without braking the bank.
That's the route I would go. In the end, you'll spend maybe $1500 or so at most, but you'll have a top shelf lift on your Jeep, no cheap garbage. Since it's only 2.5" of suspension lift as well, you'll avoid the hassle of adjustable control arms and having to change your pinion angle and such.
That's solid advice, I promise.
Hey chris, i was trying to find the ome lift on other websites and it saying that its only for the JKsthank yo
http://www.morris4x4center.com/old-...-with-nitrocharger-sport-shocks-ometjhks.htmlHey chris, i was trying to find the ome lift on other websites and it saying that its only for the JKs
Agreed. I went with the OME LD kit, but after seeing @CodaMan's rig, I would have done the exact same thing:Putting your own lift kit together is a perfectly legitimate way to go.
Figure out what it is you want to accomplish, figure out the parts that accomplish your goal, and away you go. Lots more complicated than writing a check and waiting for the big brown truck to arrive. Works great if you can stay focused and have patience.
x2Check DPG offroad. If interested on OME gave a call to Dirk. Time well expend.
thank yo
