Bead locks with clamp rings and bolts are a maintenance item. The load range is limited due to the bolts only having so much strength. This is a big enough issue that Champion has stopped making bead locks for anything that sees pavement and others have quit making stuff that will fit a 3/4 ton truck and larger.Understood. At a point the current TJ will become a non daily driver and off-road only and a replacement stock TJ will be used. That won't be for several or more years. Just looking for what's good and what will fit the bill later on.
If you don't mind, how are they more work on the street? I truly don't know.
I get it's expensive I'm trying to research what the preferred brands are and realize my request of cheap ones isn't viable.
Withdrawing the $150 range. Just looking for ideas and if single or double bead locks are preferred.
Bead locks are a solution to a problem. If you don't have the problem, you likely don't need the solution.
