This is exactly lots of folks use rotellaIt has a lot more zinc for cam and lifters.
I am going to have to respectfully disagree with the last partThere is no "best oil" for your Jeep.
As long as you run the right oil weight, you can put any oil in it you want and it's not going to make any difference whatsoever, period.
Hey guys, what's the best Oil for a jeep Tj 4.0 97
Why do you need a larger filter?While we're on this subject, is there a larger oil filter than what's specified? Plenty of room, might as well use a larger filter.
Longer time before it needs replaced.Why do you need a larger filter?
Is this the Rotella you use ?I use rotella 10w-30 with mopar filter.
Dont worry though, the 4.0 is not picky. Just put in whatever cheap 10w-30 you can buy and it'll be happy.
Increases oil capacity slightly, can pass oil a bit easier, there's room for it, so why not?Why do you need a larger filter?
