Best stock fog light replacement
Stretch
Alberta
Down one stock fog light. What’s the best street legal fog light for the TJ? Hoping to use existing location on stock bumper.
Cheers
Steel City 06
Pittsburgh, PA
I bought the KC slimlite fog lights. They have 2 kits. They have a 55 watt kit that’s plug and play and a 100 watt kit. I bought the 100 watt, and it’s almost too bright for street use. The 100 watt one you should run a separate relay for
Stretch
Stretch
Alberta
Thanks! KC is all I’ve been able to locate so far. Looks like the 55 watt might be the winner.
RAWZ08
Texas
I used these cheap versions, can be found on amazon. I did have to redo the wiring without the factory plugs, i couldnt find any and due to how it was damaged (some one literally ripped it off my bumper) i couldnt use the old ones. But they were cheap and look about the same. Definitely not as sturdy plastic.
Remarkable Power FL7091
Steel City 06
Pittsburgh, PA
The only thing I didn’t like about the KCs was the rock guard, but fortunately they just pop off so you can run it like the old lights
