I just upgraded to 33 x 10.5 tires on my TJ and am trying to find the best option to mount it on the factory spare tire holder. I have factory Gambler rims which are 15 x 8 with 5.5” backspacing. The older 30 x 9.5 factory spare fit perfectly with these rims and right against the snubbers.
I have a 1.25” body lift and though I haven’t checked yet, I think it should clear the factory bumper. If so, then the main question is how to space it out the 1/2”-1” so that it fits.
I was thinking if I could get just that much offset I wouldn’t have to mess with the snubbers and it could still be pretty tight to the tailgate.
If that’s a good path, then the question is how to get that amount. A few options I’ve considered:
1) Get longer wheel studs on the carrier and space it out that way—perhaps using a wheel spacer so the longer bolts have some support.
2) Space out the tire carrier itself from the tailgate with some sort of spacer or plate for the 4 bolts that attach the carrier to the tail gate.
3) use a 1” wheel spacer which might just fit perfectly.
4) Buy a new tire carrier that bumps it out a bit. The ones I’ve seen push it out 2”+ though which is more than I want or need.
5) Buy an adapter to push it out. Again, the ones I see are 2”+ which is more than I want. Also, they lift the tire up which I don’t think I need.
I do not want to get a new bumper with a tire mount. I already have a bumper.
Or, is there some other solutions I’m just not thinking about?
I’ve read a lot of posts but they all seem to have slightly different ideas and conditions.
