Bestop replace-a-top vs supertop
Adrian_A
California
been debating on which soft top I should buy. really wanted a "slantback/fastback" design but since I have an aftermarket roll cage I'm pretty sure the fitment would be off and leave a lot of slack. so im down to just replacing the fabric and keeping my original frame. I have also seen on here that the Bestop is by far the best option to go with so now I'm down to 2 options.
Option 1: is the Bestop Supertop Soft Top Replacement Skin. https://www.quadratec.com/products/11111_1XX_PG.htm
Option 2: is the Bestop Replace-a-top Soft Top. https://www.quadratec.com/products/11132_21XX_PG.htm
they both are the same price but not sure if one is better than the other in terms of material, thickness, color, and what's all included.
I believe Option 1 is only if you already have a Supertop (Fits over existing Supertop® hardware.)
If your frame is good, get the Replace-A-Top. If your windows are still good, you can also order just the canvas if you call Bestop.
Also: Fuck Quadratec. You're better off ordering directly from Bestop.
Reactions: Akitadog
thanks, yeah ill probably order from bestop, just used quadratec when i was comparing other brands/prices. window zippers are messed up and its all faded from the sun would look right so ill just order a whole new replace-a-top.
thanks
Reactions: AjRagno
