Ive not done this, but I can pretty much always find what I need for the TJ at ACE.
ACE had everything except the 7" bolt. Maybe yours will have a bigger selection.
oh bummer, I bet they have a 6” and 8”. Can you trim it down if they have something longer? Keeping a nut installed - grind off the extra inch and unscrew the nut to clean up the threads.
Working on my install today and noticed the measurements are different in my instructions than what you said the instructions told you. They’re telling me longer measurements. Top hinge 6 5/8” from door opening and bottom 6 3/16”. Curious if some sets had updated instructions to these incorrect measurements?Mount the tailgate pieces first, including the carrier. Get them tight. Then pay attention to the tub mounting system. I did this, but then I went off bestops measurements in the instructions. They say to have the top mount at 6 3/8" from the tailgate edge, and the bottom 6 5/8". Those measurements are wrong, mine are further out. When your ready to mount to the tub, just take sure your carrier is parallel to the tailgate. Also, an additional jam nut may be necessary on the upper mount on the tailgate.
Do these new measurements match up when you do what @tworley described by letting the carrier tell you where the holes need to be?
@tworley i actually just used the measurements as a guideline. Like you said @jjvw i let the carrier tell me where to drill. I installed the roll bar bracket first and used the brackets holes to drill pilot holes then went from thereDo these new measurements match up when you do what @tworley described by letting the carrier tell you where the holes need to be?
What did your measurements end up being? Just curious how it compares to the instructionsHere’s my final install. My tips would be to use the passenger side bracket holes, top and bottom, be your guides to make your holes in the tub. Make small pilot holes to see where you are in relation to the bracket holes on the other side.
My other tip is keep track of your hardware. I can’t find my torx bolt that holds the seatbelt assembly
I’d have to measure. I really just used those recommended measurements as a guideline where to put my first pilot hole. After I found out where I was on the inner tub in relation to where the bracket hole was, I adjusted where I either enlarged the hole or I moved to make a new pilot hole. I used the smallest bit I had in my drill bit arsenal for my pilot holes. Only missed one where I had to move over a bit but the hole was so small I just put touch up paint on it and moved on.What did your measurements end up being? Just curious how it compares to the instructions
