So i just put my jeep back together and now have a bit of a problem.
I was moving is out of the garage which took some sharp turning and small nudges forward and back since there’s a large dumpster in my driveway (house remodel) blocking my exit from the garage.
It started out fine but then it wouldn’t turn at all. Then a loud pop and it turned good for 1 or 2 turns then it would happen again. It didn’t matter if it was left or right. I got out every time this happened and looked at everything. There is plenty of clearance, nothing is hitting anything. If I jacked it up it would turn easy and would not bind. But as soon as there’s weight under it and a couple turns into it it would go again.
I just tried to make it happen again (it was “stuck” and it worked fine, but now when turning left almost at full there is a “pop” but nothing really happens.
Just so ya know what I have, it’s a rubicon so Dana 44, full traction track bar, currie tie rod and ends RCV axles PSC steering gear (about a year old but 0 miles and I did the bleed instructions and have no air bubbles. New spicer ball joints
