Who uses an app like Torque to extend the dashboards of their TJ with live readings from the PCM? What have you learned? How has it help you? Does it create anxiety?
View attachment 51873 View attachment 51874 View attachment 51875
For me, it isn't about logging. It's about live data.I use engine link with a wifi enabled obd2 connector, but just to read and clear codes. The information is nice but not worth the hassle for me to log all the time.
Wait till Amazon has the kindle fire on a good sale. (I got one for 50 bucks. 7")Then you can mount it and use bluetooth to steam the data. (Bluetooth obd2 for 20 bucks)For me, it isn't about logging. It's about live data.
I use it for CEL...don't use it for the live data...not really that concerned with that
I will admit I have one pluged into my f150 and use it to monitor everything. But i don't have one in my jeep. Maybe someday.Here is what I've used mine for over the last 5 years...
-Diagnose bad o2 senors
-Failing thermostat
-Study the effects of a true cold air intake and hood vents
-Determine the need to and another thermostat as a result of the cold air intake and hood vents
-Train myself to be a fuel efficient driver
-Calibrate the speedometer to GPS to a high degree of accuracy
-Read and clear CEL p-codes
Anyone else find uses for this ability to be hyper aware of your engine?
Another thing I have used mine for is reading codes for other people, friends, coworkers, the occasional stranger. Even if I can't help fix the problem, it helps take some of the mystery away from car problems that most are clueless about.
