Body lift on top of suspension lift
JensF1
Casper, WY
Are there any risks/problems/drawbacks to adding a body lift to a TJ which already has a suspension lift? I'm looking at an '04 Sahara with a 2" OME suspension lift. I'd like the jeep higher to accommodate 33" tires and would consider adding a 1" body lift. I'm totally new with this, so any input is very much appreciated.
TheBoogieman
Disturbed American
C-Ville VA
No drawbacks to a BL. I had 3.25" total lift on my old Sahara. My bumpers and winch weighed it down a little. I originally had 4" total lift with 33s on my 04 Sahara.
DaveC
Gilbert, Arizona
No downside at all. I'm running that exact setup, with plans to bump from my current 31s to 33s when I need tires. The OME springs got me ~2.75" of lift, and with the 1" body lift, I'm at just under 4" of total lift.
JMT
The Jeep Guy
Gitter done!
L J
Ranchos aren't real
Dumont Dunes
installing an aluminum 1.25" body lift is actually the best bang-for-buck modification and highly recommended
Reactions: JMT
limitz
Seattle
Help me out....MML? not sure what that one means
BL is going to move the radiator fan shroud, you'll need the motor mount lift to realign that. Motor mount lift will actually help your driveline angles since you have a suspension lift installed.
If the previous owner has a t-case drop for the 2" lift, you can remove that as well. Bottom line there's no downside to a BL/MML. Gives you a lot of space to work underneath the Jeep, and everybody loves a bit of buttcrack.
J
JensF1
Casper, WY
Thanks for the explanation
limitz
Seattle
Reactions: LONGJP2
