I'm thinking perhaps there is some confusion going on. You have mixed up every aspect desirable and otherwise between your offerings and some are in direct violation of your logic of transferring vibes.
You need to understand the anatomy of a OEM body mount. The top rubber piece that sit on the frame mount is solid rubber. There is a mushroom cap with a hollow stem that drops down through it and that is capped off on the bottom with a steel washer that the bolt goes up through. The washer has a rubber cup bonded to it and the upper edge of the cup butts up against the frame mount. The weight of the tub sits on the solid rubber upper, the upward movement of the tub on bumps is controlled by the lower cup, and the compression of the assembly is determined by the tube that runs through the whole mess. All of the isolation is handled by the OEM mount so adding poly, aluminum, rubber or wood on top changes nothing about the amount of vibration transfer.
Due to the design of the mount needing a decent torque value to maintain its integrity and functionality, nothing should be put on top that can not achieve the same torque value on the fastener.
The JKS squishes when tightened, not good.
The Savvy works perfectly since it is aluminum.
The Daystar is a much harder poly than I prefer and it does have the tube inside to develop the torque, it is just a very hard poly and transfers more vibe than OEM.
