Decided to put up a short review on this Exhaust stud kit since I wasn't able to find a whole lot of info on them before buying them. I've got a very leaky exhaust manifold gasket that I will be replacing soon, and I wanted some upgraded hardware before diving into that project. First I checked ARP and wasn't able to find an exhaust bolt or stud kit for the 4.0, I think they used to make one but it doesn't appear they do anymore, though you could probably piece one together if you know what sizes you need.
The only kit I found available is from Boostwerks Engineering, it's his version 2.0 stud kit with custom washers and mechanical lock nuts all machined by Boostwerks out of Grade 6 titanium. They look absolutely awesome, his surface finishes are very nice on all three parts, but the proof is in the pudding.
The studs are 3/8"-16 on one end and 3/8-24 on the other end.
The major diameter spec for 3/8"-16 2a threads is .3737"-.3643"
The pitch diameter spec for 3/8"-16 2a is .3331"-.3287"
Boostwerks averaged .3715" for the major with a range of .371"-.372"
Pitch diameter averaged at .3274" with a range of .3269"-.3279"
Major diameter spec for 3/8"-24 2a is .3739"-.3667"
Pitch diameter spec for 3/8-24 2a is .3468"-.343"
Boostwerks averaged .3722" for the major with a range of .371"-.3735"
They averaged .343" for the pitch diameter with a range of .3428"-.3435"
I measured all 11 studs with my 0-1" Brown and Sharpe mic and a brand new set of Brown and Sharpe thread wires. Everything was very consistent, no significant tapers in the major or pitch diameters and most of the measurements were within spec, though all of the pitch diameters were towards the bottom of spec and some were out of spec by a thou or two on the 3/8"-16 thread. This may pose a problem in other applications, but for an exhaust stud a thou or two under the pitch diameter spec shouldn't be a problem at all.
All of the studs are broached on the 3/8-24 end with a 5/32" hex to aid installation. The hex looks very good, it doesn't appear to even have a witness mark on the flats from the drill before the broach, it is a fully formed, and nice snug fitting hex.
The minor diameters on his lock nuts were all consistent around .336", spec for 3/8"-24 2b is .330"-.340". I will be taking these into work to test with some thread gauges this weekend, but I don't expect any issues.
I certainly wouldn't hesitate to purchase these again in the future, $125 is pretty damn reasonable for the amount of machine work involved to produce the entire kit. I will continue to update this as I get the lock nuts measured and get the studs installed
