Braided brake hoses for 05 LJ
Chopper 5623
Mount Sterling, Ohio
I've been looking for stainless steel brake lines while I'm going to the brakes on my Wrangler cannot seem to find the ones for the front axles, does anybody know a source for those? Thanks in advance
RockAuto sells a Dorman product that can be had extra long for lifted applications. Although these are not coated they are braided stainless.
Crown makes a great product that I’ve had trouble finding recently and was told Crown is behind in manufacturing due to a redesign. The Crown ones on my LJ are sweet. I buy the Crown ones through Quadratec but again confirm stock.
And. The LJ front lines are the same as the TJ lines.
Why do you want stainless steel brake lines? They don't function any better than rubber brake lines and won't improve your braking to any measurable degree.
Is your jeep lifted? If so, these Dorman brake lines will work. They were suggested to me by @mrblaine , our resident brake expert on this forum. His company, Black Magic Brakes, is also linked below.
https://www.amazon.com/gp/product/B00IY2C63K/?tag=wranglerorg-20
https://www.amazon.com/gp/product/B00IY2CHHK/?tag=wranglerorg-20
https://www.amazon.com/gp/product/B00IY2CBTY/?tag=wranglerorg-20
https://blackmagicbrakes.com/
There are two companies with Crown in the name, Crown Automotive which is the sorta junky company and Crown Performance here in SoCal that makes lots of stainless braided brake line kits here.
That said, we use as much of the extended OEM style Dorman stuff as we can make fit. Just a good solid way to do things.
Reactions: Weasellee
I have Crown Performance brake lines on my 97. Completely unnecessary but we have a lot of sticks and brush out here and I'd like to think they're holding up better than most.
I got black ones...but you can order in different colors.
-Mac
These worked great on our 03.
I did forget to specify Crown Performance. Thank you.
