So I’m doing a complete brake system overhaul.
When I got to my rear brakes (dana44 with drums) I knew I had a leak somewhere but was kinda hoping it was the wheel cylinder.
Turned out to look like the axle seal instead so I researched that on here and ended up ordering the Timken seals and bearings as recommended in another post by Jerry and some others.
Now I’m wondering if I should have considered the spicer bearing / seal package that includes the backing plate as well.
I won’t know the condition of mine until I remove it.
Some questions though;
Do I need to disassemble / drain the differential to remove the axle? Or is that only on the Dana 35?
Do I need to do all the axle work before finishing my brake job or are they separate and inconsequential to one another?
Should I stick with the Timken parts and order the backing plates or just try to reuse the existing plates?
Thanks in advance
-Jason
Thanks in advance
-Jason
