- Price
- $500
- Location
- Breckenridge, Colorado
*PENDING*
Brand new set of Genright aluminum corner guards for a TJ, all mounting hardware included. Standard wheelbase, easy to cut/modify for a stretched wheelbase also.
I ended up with 2 sets as the initial set wasn’t mocking up correctly initially (or so I thought), ordered a 2nd set but they didn’t get here in time for our trip to the Rubicon so I went ahead and modified and installed the 1st set since I had to cut them to fit around my spare tire holder.
The 2nd set (these ones) mocked up exactly the same (small gap at the very top of the corner above the taillight), I ended up putting the driver side on a large press with a 7” radius die and added about 1-2 degrees more bend to see if that would tighten it up, no real change. Turns out, once I actually bolted on the 1st set it snugged up just fine, you can see the installed set mounted on my Jeep when you come pick these up to confirm they fit just fine once you get them all bolted up.
These have been sanded with a DA sander to clean them up as I was contemplating running them instead of the others but decided against it.
$500
Located in Breckenridge, drive to Denver frequently and could bring with me if timing was correct.
$500
